Wiper Motor - check!
JPSmit
Well, the wiper motor works perfectly. $10, 2 hours, new brushes, new grease and I'm good to go. Here is my question. I did photo it for posterity. If anyone is interested I'll write it up.
BTW, someone mentioned that their wipers won't park. I suspect I know why. The switch for the parking mechanism is a spring loaded pin under the main cog gear. There is an indentation on the backside of the gear. When you shut off the wipers, they continue to turn until the pin engages the indentation, shutting off the motor in the correct position. In a best case scenario, the indentation is filled with hardened grease - as mine was. In a worst case scenario, the pin has worn out. The way to find out is to remove the whole unit and remove the cover followed by the main cog. Don't worry about taking off the arm that moves the spring that moves the wipers (unless you want to) Instead, on the outside of the case, there is the shaft (it's slotted) of the gear. It's held on by a spring clip. remove the clip (watch that it doesn't fly away as it is hard to find - don't ask me how I know) remove the gear and all should become clear.
Yep...photos and writeup required (no good deed goes unpunished)!!! :smile:
I'll be doing the same this winter for the wiper motor in the Spridget Project (modified cable and single wheelbox/wiper). Your experience and advice will be appreciated.
I didn't want to have one at all, figuring that Rain-X and speed would handle the problem, but I have concerns over being stopped and ticketed without one.
If it turns out to be too big a deal I my just go with an after market product like some you see on street rods, the kind that attach to the top of the windscreen and have motor and wiper all in a single compact (lightweight) unit.
Ray
Nice job...thanks. Downloaded the pdf and saved it.
