Hi
I installed the windscreen and had the finisher installed but was not happy with the way the outside of the gasket laid against the frame.
I removed the finisher and have made every attempt I can think of to ensure the gasket and windscreen are pushed into the frame that I can.
However, when the finisher is installed the lower corners of the gasket want to roll under themselves.
Looking at it, it appears that the windscreen and gasket really don't fill the frame as the original did. It gasket appeared to touch the inside of the frame all along it's length. This new one does not.
These photos are taken with the finisher removed.
See photos at https://www.flickr.com/photos/norton47/sets/72157601936868583/[/img]
It would seem the windscreen is not as big and does not curve enough to allow the corners to really fit correctly. The the gasket and windscreen are from Moss,based on a local recommendation. I also have a TRF gasket.
Would it be worthwhile to try the other gasket?
Do all replacement windscreens fit this way? Should it not fit better.
It seems to fit on the inside correctly.
Have I done something wrong?
