window
artpart
Member
The passenger side window keeps coming out of the glazing seal when the window is rolled down. Someone suggested using a 3M adhesive to keep it in place.
Does this sound right? If so, what sort of adhesive?
artpart, I used 3M weather strip. the hard part was to get the window fully home in the channel. I ended up taking the whole thing out, putting weather strip on the rubber then onto the glass. Let it set until all was dry and using a rubber hammer to close the channel up a bit and the using same to drive it on the window after applying sealer on it also. Force is not to be used as glass is strong but very finicky when hit from any angle except straight on. If I recall, I held the glass in my hands while the wife was giving it a whack, maybe a stack of towels on a table would be better.
Good Luck, Wayne
PS, yeah, I know getting it out of the door requires taking off the rubber channels and clips, PAINFUL.
