jjbunn
I set about replacing the inner and outer door window seals, armed with new parts from Moss.
Removing the old seals was easy enough. Attaching the inner furry seal was a little challenging. The DPO had installed his the wrong way up i.e. with metal strip upwards, which threw me off the scent for a while.
It became obvious that I needed to remove the window rails to place the endmost clips, which was annoying since I'd just re-installed them after re-lining with new felt. But after a short while I had all the clips in position and the inner seal nicely attached to them.
Then I came to do the outer door seal. First problem was that the Moss part was too long, so I had to trim it at both ends. Then I followed the instructions that came with my Moss door strip clip tool, and placed all the clips onto the seal first.
This turned out to be a mistake: it's nigh impossible to position the seal so that the clips can attach to the door in this arrangement. It's obvious that the clips have to be pushed on from underneath, while holding the seal in place.
After huffing and puffing, and taking a piece of skin off my forehead (the clip tool developed a life of its own and sprang at me viciously), I decided that the job should be left for another day.
Does anyone have any tips for getting the outer door seal clips on?
