Water is unlikely to get into the coil connector unless you drive with the hood open, and even then the rubber boot should protect it. Some moisture will get on it during a rainy drive, however it is unlikely to penetrate the boot. If it was to get inside, I don't think it would get back out easily, no matter which way the coil was mounted. So again, it really makes no difference if you mount it pointing up, down or sideways.
