mightymidget
today I started tinkering with Bugeye, seems the front of my bugeye was in a wreck and bonnet should have been replaced, but instead someone got real creative with bondo, check it out 1" thick, all of the rust is from the bondo. BONDO lets moisture pass through DO NOT use it on bare metal. Dynoglass is waterproof and will not get rust between it and the metal, but epoxy primer should be applied on bare metal!!!!
the headlight buckets have been welded in place and don't know if I can save this bonnet or not
I was using a hammer and wood chisel to pop the bondo out, I was really disapointed in what I found today
Frank is correct....there are some of the newer materials that can go directly on bare metal, but the old stuff needs epoxy primer.
