G
Does anyone know the correct voltage for the hot wire from the light switch to the rheostat? I cooked my second dimmer yesterday. I tested the volts and it is 12.4 volts constant, engine running or not when the master light switch is on. The second dimmer worked well for about 2 total hours and then very dim only.
I have since bypassed the dimmer and dash lights are full bright and wires are not warm to the touch. I am stumped as to why both switches cooked at only 12.4 volts.
