mountainman
What do you think, white walls???
TFB said:Either way, your car looks great.
The problem with Robson's book as a sole reference -- and it's the same problem with most books on Triumphs and other British cars -- is that they are written very much with a "home market" frame of reference. That's fine, but often it has resulted in a "portrait" that ignores the majority of cars built, which were export cars and especially those going to the US. There is a good bit of US sales and promotional literature showing TRs and other models with whitewall tires, wide until about 1962 and increasingly narrow (but still present) after that.TR6oldtimer said:I also referenced "The Triump TRs, a collectors guide" by Graham Robson, and other references, all the photos of the TR3 and TR4 were with black wall tires....
I remember them very well! Definitely a palatable solution...and it allows you to still have a good and/or inexpensive tire with "the look"!mountainman said:Andrew, I felt the same way as far as $$$$ and since the car had new tire when I purchased it. So I found a set of Port-a-Walls on the net for around 50.00. I sure some of the menbers remenber them.
Greg
