TR2/3/3A Which set of rockers would you go with? [TR3A]
Not sure which ones I would choose, but welcome to the BCF!
And you're user name is perfect!
:cheers:
Mickey
All I can tell you is that SPorts and Classics does not make the rockers, so try a little more searching for the manufacturer. Kilmartin in Australia makes them I think and their products are quality. I think there was a company in the midwest that makes them also. They had good comments on a previous post. Here is a link.
https://c2cfabrication.com/store/popup_image.php?pID=1071
Jerry
If they are as described. They will be worth the money. All the other rockers do need a lot of work to get the correct radius to match the door. You can tell when it is not done right when the sun casts a shadow across the bottom edge. It is very noticable. Welcome to the forum.
I have installed two sets of the rocker panels(outer sills) from Sport and Classic. They fit well, however some modification was necessary at the front of the sills to accommodate the front fender. The indentation provided was not quite deep enough for the fender edge, and the angle of the indent was somewhat off from the fender edge angle. Required a small amount of hammer and dolly work,welding, and leading at the front of the sill.
Robert
