Keoke said:Michael.
I do not have the model number handy but get the yellow top it will cost you a penny or two more but it is worth it because the Optima deep cycle batteries are multi-purpose, meaning that they function excellently for starting as well as for deep cycle use.--Keoke-- :drive
Actually, they are AGM, not gel. You are correct, they don't release gases under normal conditions. If they are overcharged (not usually a problem) they won't release gases for long and will be ruined.Johnny said:And happy new year to you. Refresh my memory...
Optima's are better why?
Because they are gel filled and won't release gases that corrode metal?
Healey 100 said:I have had a couple of Optima batteries (red top, 6V) and have little good to say about them. Mine worked OK for a couple of months but then started losing their charge when sitting rather quickly
I finally got tired of trying to figure out how to use them properly. They are sure not cheap, and
I can't understand the rave reviews I keep hearing about them.
