TR6 Which harness for 74 tr6
Wike
Need to replace the wiring harness in my 74 tr6. Any suggestions on which harness to purchase. I heard there is a supplier who has upgraded the harness, wire size, relays, etc.
Or should I go to the normal suppliers, TRF, M. VB?
I just replaced the harness in my 71 TR6, I went with the original harness from TRF, and got Dan Masters book too. the wiring has the correct colors so it was easy to install, I did add relays to the head lights and electric fuel pump. I cant talk about the other harness with the relays built in but from the pics I could see when they posted here, I believe the wires are not color coded so its a lot more work and you will have to put the connectors on each wire too. I would go original if you want an easier installation. the only other thing was I bought all new bullet sleeve connectors from british wire and about 20 bullets just in case, and I bought the heavey gauge brown, brown white wire and ran a parallel to the amp gauge and to the starter for my larger alternator.
Hondo
Don't know about others but my Masters panel was color coded. But I do go along with Hondo on his suggestion. If you want easy and right go stock. If you want upgraded and a fair amount of work and thought . Go with the others.
