BJ8 900 miles on a new rebuild and its all down hill from there. A friend that will remain nameless had the motor overhauled by shop all seemed great car never ran better till it started to knock really bad he did the right thing shut it down and the shop that rebuilt it pulled 2 rod caps- bearings down to the shell backing. Long story after about the shop and its back into his hands. So a few of us are helping out on the tear down and find really over tighten hardware like impact tight all hardware is intact no broken hardware so.....
1) During the new rebuild should the rod bolts be replaced? ie are the replacement bolts that you can get any better then the old ones. Threads do not seem stretched so what the thought? Car is not raced standard rebuild.
2) #1 rod has the best bearing and its worse as you get to the fly wheel we have been told the motor had oil and all bearings were STD size. will be sizing everything soon when all is apart.
Well thanks for any input you have- Will update!
Hi Guest!
