I have a 1962 TVR Grantura MKIIA with a MGB engine and I am having some problems with wheel wobble. I am hoping that someone on this forum might be able to help me. My car has knock off wheels and the other day my wife was following me down the road and noticed that the right rear wheel had a wobble. I jacked up the rear end and noticed that the right rear wheel would spin easy and it would get hard in a spot and then rotate free then hard again. The two “hard” spots were about 180 degrees from each other. Upon removal of the wheel, the hub would turn the same way, with two “hard” spots. Once I removed the brake drum, the axle would turn free with no “hard” spots. Is the brake drum bad/out of balance or is it something else? Also, is the brake system from an Austin Healey?
