About 4000 miles ago I decided to take all of my wheels with new Vredstein tires that I had mounted by hand (yowza, that was big fun using the three little tire irons...). I figured I should have them spun balanced and after reading all I could about how to do that with the splined hubs I found a local shop that could handle it. The result was OK, or should I say not noticeably worse but I was always leery of the amount of weight they used. Today I just finished flipping the tires on the front, due to wear on the outboard edges (next on the list are eccentric bushings for camber adjustment). When I was reinstalling the wheels I noticed that just by observing static balance while mounted on the hub, I could find the heavy side. It was painfully obvious they were significantly out of balance if I included the brake drum, which this procedure did. I proceeded to balance both front wheels this way and removed more than half of the weight AND ended up with the remaining weight in different locations on both wheels. Drove the car and WOW, very noticeable difference. Also found two broken spokes that were not noticeable until I pulled the wheel off by the spokes. Didn't cost me a dime except for band aids and peroxide.
Hi Guest!
