texas_bugeye
HS Type (Plastic float)
To adjust.
Hold the float lid assembly in the inverted position and measure the gap between the float and the lid. For the early type of plastic float with a metal lever arm the gap should be between 0.125" and 0.187". Small adjustments can be made by bending the metal lever arms. OK I GET THAT
For later all plastic floats the clearance should be between 0.062" and 0.187" but this type is not adjustable.
What the heck do you do if your like me and have the later?
I'm thinking of putting a washer - spacer under the seat to lower the float level. Anybody done this or have another answer?
To adjust.
