One more question to the group while I am at it. After an excursion I can smell some kind of oily smell and lift up the hood and see a very small amount of smoke coming up from the oil filler hole. If I take off the oil filler cap it puffs out a little bit of smoke and that is that. Is this normal? Is it what is called 'blowby'? I just did a test where I take the cap off and hold my hand a few inches above the pipe at idle. It is a continuous stream of hot air not unlike the output from my little heater inside the cabin. You can feel the rpms of the idling engine which does not surprise me but is this what I should be feeling OR could it be time for rings or ???? I have done compression tests recently, wet and dry, and while it is not up to newly rebuilt standards it was within specs. I will do some more compression testing and report back but I am just wondering if all, or most, of what I am describing above is relatively normal.
Thanks very much,
Jim Lee
Thanks very much,
Jim Lee
