G
Ok, here we go. Replaced Hazard light switch which indeed did correct the blinker problem..Had the radiator repaired and reconditioned. Trunk has been repaired and repainted, but I will need to go back because they did a poor job. another story.
I removed the driver side door panel to lubricate the mechanical. Learned that my courtesy light is gone, will need to reorder.
But, in the process, I now have no power to my radio. It is aftermarket.
Any ideas? Nothing, nada when I push the power button. All 4 fuses appear to be intact, although the third from the top seems to be missing a wire, wierd! only one going out,none coming in so to speak. Also, clock is not working, it used to .
Thoughts?
Thoughts?
