I'm not familiar with the term Stillson....please explain.I have also put a Stillson on the extension and locked it against the frame.
Bob
They are a self tightening pipe wrenchI'm not familiar with the term Stillson....please explain.
I think someone mentioned there was a potential problem with that rope trick but I cant remember what it was?Another old trick is to put a length of rope into a cylinder so that the pistol cant come to TDC(cant compress rope)
Mad dog
The
How about under the car put a block of wood up against the flywheel and a jack underneath the block of wood to add pressure to hold it against the flywheel?The last time I put a chunk of wood in the hole the starter came out. The flywheel bits into the wood and wedges in place.
Hi,
If the engine is in the car, I have removed the bolt by putting a socket & breaker bar on the bolt. Rest the breaker bar on the LH frame rail. Remove the coil wire and put the car in neutral. Bump the starter and its loose. Its works on my TR-3a.
Roy G
