Westfield_XI
Would an upside down t'stat cause overheating? Or would it open anyway at the correct temp and let coolant flow? I am trying to track down an overheating issue in my 1380. The car runs fine, electric fan comes on, but it still gradually climbs to 180 to 210 and if I shut down it seems to get a vapor lock in the pump. That is: it will not cool off even though the car is cruising again and the airflow is restored.
I found that the t-stat was installed with the "cage" side down in the block. I flipped it 180* and the car seems to heat up slower, but still climbs to 210 when stopped and idling. And it is still reluctant to cool down.
