texas_bugeye
Well here is my dilemma; it is so minor I do not know if it is worth chasing.
Car runs great no problems. So here the deal I can be sitting with it running forever and it won’t leak a drop of oil I know impossible. However, when I shut it down it leaks a spot the size of a quarter out the front crank seal (948 with newer style seal not the rope) it also has the can style vent in the rocker chest cover just open no hose to it. No road tube. Why does it do this? Could it be there is crank case pressure shortly when it shuts off? This is the only leak on the car and it has done this since rebuild years ago. Should I just leave it and be thankful? I’m just confused as to why only when it shuts off. When I put Rivergate kit in I bought a new seal and front cover gasket. Refit it all exactly the same results crankshaft showed no ridge or bad spots and seal looked good .
