Hi Everyone,
I'm running a TR4A engine with SU HS6 carbs in my 1959 TR3A. When I rebuilt the engine a couple of years ago I found that the camshaft was damaged (lobe wear due to incorrect oil) anyway I replaced the cam but used a servicable one from a TR3 engine not realizing that they were a different "grind." Since the rebuild I have noticed that I have to set the ignition timing closer to TDC rather than the prescribed 4 degrees BTDC to stop the engine pinking even when using premium fuel.
My question is, should I be using a TR3 Distributer to match the TR3 Cam?
Regards,
Quelch
Regards,
Quelch
