bugedd
When I got my BE, it came with the Weber DGV conversion and the SU's in a box. The Weber is going to take some leaning out via jets to make it run right, and that made me wonder about putting the SU's back on. The motor is a stock 1275, and I may put a cam in it at some point, but that's probably about as far as I will go with the motor.
So what do you guys think, put the SU back on, or dial in the Weber? And should I determine which SU setup it has, and if so, how do I do that?
