Quiz of the day, I am taking apart a spare heater motor from a TR6 (I think they are basically the same TR4-6) and a spring comes out of the casing, it is a compression spring (no hooks on either end), slightly less than 1/2" (0.46" on my caliper) in length and about 0.19" in diameter. It cam out when I took the motor apart, could not tell from where, event when I took it all apart, all the parts that seemed to be needed to make it run and hold things in their proper places were there without the spring, so I put it back together without the spring and it works fine, but don't want anything to blow up or wear out prematurely. Don't think there is an exploded drawing of the motor in the parts books, so no help there. Maybe more precisely than what am I? Where do I go and what purpose do I serve, some kind of spacer with a little flex maybe?
Hi Guest!
