Wet trunk
Keef
Hey folks, yesterday I gave my 92 XJ6 a good cleaning. I removed the spare tire and carpeting in the trunk. I found some drops of water in the bottom of the trunk. I checked the seals and all seemed to be in order. I did notice alot of condensation on the outside of the filler neck to the tank. The liquid was not gas. I live in a very humid area. Could this be the source of the water? Is this a large problem?
Thanks,
Keef
Keef,
You should have a drain on that filler 'box' and it should be cleaned out regularly. Don't use high pressure or it will just blow the hose off.
