TR2/3/3A weld-able ¼ cages for square nuts
sp53
The weld-able ¼ cage for square nuts I got from Moss are un-weld able in my opinion. I have tried and tried. I believe the metal has too much of some noniron alloy in it. The ones I got from TRF I could weld in and the metal looks different, like it is made from mild steel, but these others ones I cannot make stick.
I tried looking on line and found little. It looks like Mcmasters has something that might work, but is a little different.
Does anyone know of a good source for ¼ weld -able cage for square nuts.
Steve
Everyone overlooks the option of metal bonding epoxy for simple things such as this.
Clean,sanded steel. Then a bolt in the hole into the cage nut.then the cage with epoxy in the
bonding area. A temporary nut holds it till set. Repeat as needed till beer 30.....
Mad dog
Just based on the color rendering in the Moss catalog, those appear to be zinc plated or galvinized. You could try and see if the coating can be removed abrasively, make sure you mask up to do so. This is something you would need to do anyway in order to weld zinc coated steel. When welding even after zinc removal try to ventilate the welding area as best you can and wear a welding respirator while welding and until you either leave the area or the welding fumes have cleared out.
If it is not a coating on a substrate and the issue is the base metal itself, then you might consider the McMaster aligning weld nut 90955A113 if we are talking about the nut being 1/4-28 (SAE/UNF threaded). That's the best option I can think of off hand since my other "go to" places for odds and ends like that didn't show anything. The C1008/C1010 are closely related low carbon steels with good weldability. Just make sure to give things a good primer/finish application for corrosion resistance.
Bonding is another option, but I really don't like it if it is for a fastener that needs to be removed then reinstalled on a regular basis. I've seen too many bonded nut plates pop off on regularly serviced items to have really good warm fuzzies about bonding under those circumstances. That may be a non-issue depending on the specific application on your car Using a belt and suspenders approach, maybe bond and rivet?
Finally, perhaps try to get some from Rimmer Bros in the UK. In their listings for the CN2 and CN3 (elongated hole variant) cages, the renderings appear to have small bit of surface oxidation. That would be indicative of no plating. If push comes to shove you could always contact them and ask. If thier stuff is what you are looking for, it may be the option for you. I have had good expeience with them and Revington in the past on orders when I couldn't find what I wanted on this side of the water
If you only need a small number, they are not hard to fashion yourself. When I had trouble finding the right size, I resorted to making them. It's not that hard for a dozen or so. For a full car of cages I would look for a source.
I made my own and carefully spot welded them in place. It just takes some time to do so. PJ
I purchased mine from Mark Macy - Macy's Garage in Tipp City, OH. They were made of mild steel, uncoated, very good quality, reasonably priced.
Stu
