Folks,
My TR-4 has developed a weird starting problem. When I turn the key to start, then engine cranks but won't fire. However as soon as I let up on the key and it's returning from the start position, the engine fires right up. I happens just about every time but is especially bad when the engine is hot. In fact, when hot, it's harder to start and when it does it runs pretty rough for about 30 seconds. Also, when hot i notice that the fuel filter is not filled up like it is when the car is colder. Not sure if that's related to the issue or separate issue. I thought maybe the coil was breaking down so I swapped in a new one but no significant change. It seems to crank okay, so I don't think it's starter related. Maybe the ignition switch is wearing out?
thanks for any help!
Greg
Greg
Hi Guest!
