Placing this here to get the most bang:
OK - on the 3.4 conversion with Edelbrock manifold, Holley 390, mild cam, Jeff Schlemmer distributor with new cap and plug wires, MSD coil: Beginning to get it sorted out before finally putting it on the road and getting the exhaust system on it. Pulled the spark plugs to check them, and #1 and #2 are fairly sooty; #3 looks OK; 4, 5, and 6 look like they've barely fired! Idle is pretty good - just a bit lopey; revs very easily; smooths out above 1500 rpm.
What's up with the spark plugs? Any thoughts? For those unfamiliar with the engine, the firing order is 1-2-3-4-5-6, and cylinders are odd on passenger's side, even on driver's, starting at the front of the car.
Thanks,
Mickey
Thanks,
Mickey
