[ QUOTE ]
doesn't sound like a very good hobbyists project then
[/ QUOTE ]
On the contrary, I think it is a good hobbyist project. In my case I have the room in the garage, went to a used appliance place and bought a kitchen stove for next to nothing.
I bought and use the Eastwood starter kit -- had it for a couple years now. Powder coating is easy, fun, and you get immediate satisfaction from seeing and appreciating the job/part in its finished state -- and you did it!
Preparation? Usually it's into the sandblaster, blow off residual dust, spray on the Eastwood cleaner, and then hit the part with the powder. Be sure to use the nitrile gloves when handling to part after prep and before applying the powder coat to prevent oils from our skin from contaminating the part.
Clean up? I use the air and blow out the powder from the gun. I used to have to sweep the floor but I don't even do that anymore as I fashioned a "paint booth." The paint booth is a simple frame (I used square steel tubing and welded it together -- overkill but I wanted something semi-permanent) draped (and taped) with some common plastic sheeting.
Limiting factor for the home hobbyist? The size of the oven. I'd like to powder coat a complete rear end housing but can't just yet. Yet? Yes, I could even do that if I wanted to spend the cash for infrared heat lamps -- and I will someday, just not "yet."
Anyway, in my opinion, powder coating is easy and fun. Clean up is a breeze. And it is immediately gratifying. No wait and no cash outlay for someone else's labor when I want something powder coated. I just do it! Front and rear engine plates? A breeze! Water pump pulley? A snap! You get the idea, I'm sure!
Tim /ubbthreads/images/graemlins/cheers.gif
