1978, 1500 w/ Webber DGAV3D, has run "normal" (some days good, some days OK) for 4 years, 10,000 miles plus. Seemed to be running less than good the last couple of months but still acceptable, and just failed Oregon DEQ. No big deal, I know how to adjust and got through DEQ in 3 attempts. They only check at 1000 rpm. All pollution crap removed by previous owner. Only thing remaing is PCV valve installed by me a few months ago. Installed new inline fuel filter. Decided to open carb, and cleaned, installed new gaskets, new needel and seat, set per Redline and Haynes data to 41 mm. Adjusted valves to .010 (only two out slightly at .012) Checked other items at same time. Compression 150-155 (9:1 pistons and mild cam installed 3 years ago). Fuel PSI 5.5 dropping off to about 4.5 PSI at 5000RPM. Runs fine at low end, low speed. Hard acceleration 1-2 shift at 5000 RPM, 2-3 shift 4500 rpm, starting to "feel" weak at shift, 3-4 shift at 4500 rpm and it goes in the toilet, no power, feels like starving for gas. Back off on accelerator and gets better, but rough for 3 to 5 seconds, and when accelerating easy will not run above 50 MPH.
Initially felt heat related; swapped out coils and seemed to help, but not really and probably just me wanting it to be better. Finally installed new Petronix Flame thrower distributor and coil. Absolutely increased RPM and performance, but still can't go over 50 MPH. Re-set float to about 35 mm to allow extra fuel in bowl. Seemed to help but not really. Reset float to 31mm. Once again semed to help but not really. Installed new power valve in carb; no change. Now have carb off and re-soaking in cleaner. Considering changing jets to larger number and emulsion tube air bleeds smaller number to enrichen.
Nagging question; this thing ran OK until about a month ago. Nothing else change; WHAT AM I MISSING?????? Elimited fuel tank restriction by running fuel direct from 1 quart bottle under hood. Same story.
With air cleaner off I have used cardboard strips slipped through holes in float bowl cover to measure gas in bowl. At Idle fuel level is about 1". At 2000 RPM no load same. At 4000 RPM fuel level drops to about 3/4". 5000 RPM same. When "starving for gas" under load at 5000 RPM load I have pulled over and checked level still about 3/4" in bowl.
How is it that I can hold 6000 RPM w/ no load, yet I can't hold 55 MPH.
Really looking for tip on best settings for float, best jet sizes, etc from someone that really knows what sizes work.
