bighealeysource]
Know this sounds pretty lame but purchased a nice,used Smiths fuel gauge for a BN2 and although supposed to work, does not. My existing gauge is a non Smiths unit and works fine so hooked up the Smiths and it does not.
Seller swears it did work.
Assuming the seller is being truthful, it might be the case that the tank unit and the original gauge are not compatible.
Is there some other test other than simply hooking it back up to see if it works ?
Yes if you can get a Potentiometer and a battery you can apply a voltage over the rang of Zero to Maxim voltage of the battery try a six volt battery they are relatively easy to come by. If the gauge deflects during this test it says it is responsive but not necessarily good..
Know this sounds pretty lame but just double checking. The cost of a rebuilt from the UK is high so trying to avoid that route.
Well you can avoid this cost by sending the gauge to "Nisonger " and ask them to test it for you this cost will be minimal. Consequently:
1] If the gauge is reported GOOD you will need to obtain the correct tank sender unit.
2]If they find the gauge is DEFECTIVE you can then arrange to have them repair it for you.
Nisongner is one of the best OK!!!
Or, does anyone out there have an extra Smiths fuel gauge ????
Thanks,
Mike [/quote]
-----------------------Keoke--
