Marla
As a test, you can try swapping cables between the speedo and tach head. The fittings are the same, and they turn at almost the same speed (in 4th gear).
If the speedo wavers even when driven by the tach cable, the problem may be the drive mechanism for the trip and odometer. It turns only part of the time, so any binding can cause the needle to waver.
My guess is that means the speedo head is binding slightly (actually the trip/odometer mechanism) as I suggested before. The effect is much less with the shorter tach cable, as there isn't as much cable length to wind up while the trip/odo wheels are moving, and unwind when they stop.My speedo in the TR3 has been wandering by as much as 10-20 miles per hour. I previously had lubed the speedo cable. So took Randall's advice and swapped the tach and speedo cables to try to decide if I had cable or speedo issue. Both speedo and tach were smooth after the swap. So my question is ... how come? I had expected one of the gauges to be bumpy. Any ideas? Cheers, Mike
Was it fairly easy to make this swap?...I mean I am up for attemtping this operation but really do not want to get in a situation where performing something like this will cause bigger problems...MarlaMy speedo in the TR3 has been wandering by as much as 10-20 miles per hour. I previously had lubed the speedo cable. So took Randall's advice and swapped the tach and speedo cables to try to decide if I had cable or speedo issue. Both speedo and tach were smooth after the swap. So my question is ... how come? I had expected one of the gauges to be bumpy. Any ideas? Cheers, Mike
I can't recall. Do you have overdrive?
