Most early auto water pumps used the cast iron surface of the impellor as one of the sealing surfaces. These were prone to sporadic small leaks. The weep hole is there to allow any coolant to drip (weep) out before it gets to the bearings. Modern seals use a ceramic or sintered iron surface which has virtually stopped that non-sense. Original Chrysler slant six pumps had a small trough under the weep hole to divert any drippings away from the fan belt that ran right under the pump.
