Thanks for the link Bert.
"My seal came from a Swimming Pool Parts Supplies" LOL, this sort of info that is just fantastic.
The article is on page 472, text below if anyone is interested and on a slow internet connection.
Andy.
Recently there has been a couple of enquiries about 4 cylinder water pump seals. One that has been used successfully (18,000 miles over 5 years) is a Sealol ¾” Type 6 seal. The impeller which is held on by a nut is the easiest to do, although the press on type can be done, using great care and with good luck (as it is thin cast iron and could be over 30 year old).
SHAFT
Enlarge the 5/8” rear section to ¾” by using a sleeve of 19mm X 1.6mm 316 stainless steel tube secured by Loctite Super Bearing Mount. Chamfer the front of the tube to allow the thrower to work if required. A stainless steel ½” ID washer is required at the rear to seat the seal's rubber ring.
IMPELLER
Shorten the front of the impeller where it touches the ½”washer by the amount required to obtain the clearance of 0.010" to 0.020" between the pump body and the vanes of the impeller.
BEARINGS
While you are at it, replace the bearings with pre-greased sealed bearings (LJ 5/8 2RS) and you won't have to remember to grease them or clean up grease thrown around the engine bay if you are to enthusiastic with the grease gun. Discard the old oil seal and cut a ¼” slot in the holder, this is to drain any water that might get there in. Refit the oil seal holder, using silicon rubber, with the slot to the bottom. Also remove the grease nipple and plug up the hole with a short bolt.
SEAL.
Remove the protruding step on the carbon face and trial fit the seal. If it is to long replace the square section rubber ring with a ¾” ID X 3/32" 'O' Ring (BS 116) to do the sealing at the back, also the ½” washer will have to have it's outside reduced to 0.95" to fit into the seal's rear recess. The ceramic seat supplied is not used as the carbon face runs on the pump body's cast iron seat.
My seal came from a Swimming Pool Parts Supplies as I noticed when I was replacing the one in my swimming pool pump, it looked suitable for the use in the 100 Water Pump. Sealol ¾” Type 6 seals are available from Woronora Engineering 1/56 Alexander Ave Taren Point 9524 1244 and most bearing suppliers (ask for ¾” pool pump seals). MOST BEARING SUPPLIERS STOCK OR CAN GET THESE SEALS
