whitey72mg
Newbe questions.....I need to replace the water pump. Do i just order the pump and gasket? do i need anything else? Also what do I use to remove the bolt in the engine to drain the coolant. size etc...
whitey72mg said:Newbe questions.....I need to replace the water pump. Do i just order the pump and gasket? do i need anything else? Also what do I use to remove the bolt in the engine to drain the coolant. size etc...
The bolt on the engine, on my car, is a tap(Faucet thingy). It is turned by the handle to drain the engine. If a bolt is there instead than Moss or VB sells new ones if you wish for about $25.PeterC said:whitey72mg said:Newbe questions.....I need to replace the water pump. Do i just order the pump and gasket? do i need anything else? Also what do I use to remove the bolt in the engine to drain the coolant. size etc...
Get the little 1/2" by-pass hose replaced, too. Just stock heater will do better than the ribbed, prone-to-leak OE version.
Peter C.
HAN8L1965 said:When I ordered a pump from VB they included the gasket. I wish they told you, while the cost is not great you end up with extra parts. Mark
