AUSMHLY
I have water leaking, a fast drip, from two places. 1)under the dash and 2) engine core plug.
The car has been sitting for 19 months in body shops. It was running fine when I dropped it off at the body shop. Then when I started it, the leaks happened. Anyone tell me why these two leaks happened after sitting for 19 months?
#1 seems to be coming from the heater. I looked up there and can not see where the actual leak is. It drips somewhere from the area on top of the heater I think?
What plan of action do I need to take. Remove the heater? If so, what do I need to do first. Any advise would help before I start doing a lot of removing of things I may not have to.
#2, is a leak coming from one of the core plugs in the engine. The one on the left side, above where the exhaust attaches to the manifold. Residue of the leak on the engine looks kind of rusty too. Should I have concern? How do I remove that plug and replace it? I seem to be getting a lot of parts from Moss. Anyone know the part number I should order?
Thank you, Roger
Thank you, Roger
Hi Guest!
