The water will be in the bottom of the tank - does it have a drain? Can you run a hose to the bottom and siphon it to see what comes out?
Elliot - when I was taking flying lessons, I remember doing that drain-and-view test of the avgas during every pre-flight. With auto fuel, is it obvious what the water/fuel split looks like? I've googled for some examples, but none are very clear.
Tom
Outside of a contamination issue from the gas station,it's more of an issue in older cars and power equipment that have vented fuel systems. as the ethanol in the fuel will literally pull the moisture right out of the air.
Prezactly. Note that the "water" is actually a water/ethanol mix, and is likely still mostly ethanol (over 100 proof but I sure wouldn't want to drink it). Depending on how much dirt and/or dye is present, it may be other colors than off-white.With the fuel sample in a clear jar, let it rest for a minute or two, and you will see clearish "bubbles", or, a stratified layer of liquid rolling around at the bottom. It will be seperated like italian dressing that has been sitting for a while. It will be quite obvious that there are two seperated substances in the jar. The fuel will look like foggy Budweiser, and the water will look like the fluid you drain out of a coconut, kinda clearish white
I'm not sure how Stabil works; but the gas line antifreeze is mostly methanol (aka wood alcohol). It works by keeping the water in solution so it can't freeze and block the line. The small amount of water and alcohol mix together with the gasoline and get burned harmlessly.Do Stabil and gas line antifreeze actually somehow eliminate the water which came from humid air?
