lclark0624
Well, still no go. Can't get past 2500 rpm and 20 mph on a hill in 2nd.
I took off the breather and the spring/heat body, and plugged the two hoses that connect to the heat body
Then I wired the choke closed and started the engine. Started right up. Idled it until it was at runnung temperature with choke closed.
I released the wire and held the choke closed while I fed the fuel. As I opened the choke, I added fuel. It acted just like it does on the hill - no power and no more than 2500 rpm's.
Just to be sure, I manually lifted the choke in the intake and it acted the same way.
Am I missing something here, or is it time to leave the choke and look again at the ignition system?
lclark0624 /ubbthreads/images/graemlins/driving.gif
