I'm interested too but if I was going to guess, seeing how the backs of the wings are lit, I'g guess it's lens flair. Greg what say you?Greg, in that first shot, what is the upper left red shifted sphere-like thingie? The Moon?!? An internal lens reflection?
Whatever, it's spooky.
That sounds plausibleI'd guess salt crystals or just ocean spray on the lens filter. I was just a few feet away from the surf.
With a focal length of 105mm, focused out to what I'd guess to be fifty or sixty feet looking at the first shot, would IR sensitivity show such a defined set of edges from something on the lens filter?I'd guess salt crystals or just ocean spray on the lens filter. I was just a few feet away from the surf.
I really have little experience with IR imaging characteristics, only a couple rolls of IR film ever run through a camera. ISTR a dismal failure on my part to get any useful images.
GregW
Another thought came to mind. IR doesn't always reflect from black like the visible light we perceive. It can make dark objects appear quite light. The black coating inside lenses can bounce the IR wavelength where visible light would not. I can get hot spots in the middle of frame with my 35mm lens. This happens even when I know there isn't lens flare.
You've likely explained it!The black coating inside lenses can bounce the IR wavelength where visible light would not. I can get hot spots in the middle of frame with my 35mm lens. This happens even when I know there isn't lens flare.
