trfourtune
Hi all,
i am here to warn you all about rocker spacers. I have noticed that there are now delrin rocker spacers out there as well as steel and aluminum.
here is the warning: each of these spacers expand with temperature changes at different rates. Why is this a concern you ask? here's the beef, if you set your clearance gap with the steel ones at 10 thou cold,then run you motor, they heat up and expand and close this clearance to a lesser amount, lets say to 5 thou hot.Now here is the catch, if you set your aluminum spacers at the same 10 thou clearance, the hot clearance will be 0 thou. Aluminum has roughly double the expansion rate with temperature than steel. delrin is even more!
the coefficient numbers i have found are:
carbon steel-.00000633
aluminum-.00001244
delrin-.000045 to .000052
So the expansion is:
(inches/(inch of material length)) times the CHANGE in temperature degrees F
Delrin has 7 times the thermal expansion rate of steel!
IMHO this is a BAD choice of material for rocker spacers!
So be careful with the end gaps.
I have steel ones for my tr4 since the expansion rate is the lowest so there is less variation in the clearance required between hot and cold.
you've been warned.
Rob
aluminum-.00001244
you've been warned.
Rob
