There has been, for a long time, confusion as which gage is the better instrument to use. The amp gage or the volt gage. The best answer I can give is to use both and I'll give you an example why. One of our trucks instrument panels had a volt meter verses an amp meter. Seems to be the norm these days as they are simple to read and do indicate the volts in the system along with voltage being put out by the charging system. But, there is a draw back, it doesn't indicate amps. Why is that important? This truck had a 200 amp alternator in it that was putting out 24 volts according to the volt meter, but for some reason the batteries were losing their charge. So much so that a driver just made it back to the yard after dark before losing all his lights. We know the alternator was good, as it was putting out 24 volts. We changed batteries, checked all the wiring and the lights for shorts, to no prevail. Finally our old mechanic said lets send out the alternator and have it tested. Well when we got the report from the alt. shop, they said the alternator was putting out 24 volts but only 3 amps. It takes amps to charge a battery. You probably see where I'm going with this. Had the truck had an amp meter, it would have indicated right away that the alt. was bad and saved us a lot of trouble and down time. Down time is money lost. Needless to say, ammeters were put in any vehicle that didn't have one. After that, New vehicles were ordered with them already installed.
