Hello,
I have a vibration that is driving me crazy. It seems to be bad around 55mph. It is felt through the drive tunnel, I keep thinking it is driveline related. I have pushed and pulled every part on the car a hundred times over. The car is very tight, everything is brand new.
It might be the dat210 trans I recently rebuilt. This was my third trans I have rebuilt so maybe I missed something. I replaced all bearings, purchased a complete kit from rivergate. The trans works great no shifting problems. Does seem slightly noisy my neighbor reminded me that it will never be as smooth as my late model mini cooper s. Yesterday I had the prop shaft balanced, that helped a little I think.
My question tonight. I stuck my dial indicator on the outside of the rear drums; the run out is aprox 30 thou, wondering if this is too much. I then did the same on the front, the hubs have run out of 20 thou. Again wondering if this is too much.
The tires and rims are all 2 years old. I have had them balanced twice, each time by a different shop.
Thanks Phil
1966 Mk3 Sprite
Thanks Phil
1966 Mk3 Sprite
Hi Guest!
