lbc_newbie
My car is experiencing a vibration at 35mph or so. It worsens if you try to go any faster. The mechanic's thoughts on this are that the drive shaft is at a severe angle causing the u-joints to bind. I have a 78 Midget with a 1275 and Datsun transmission. We recently installed the rebuilt motor (it was pulled and installed with the tranny). Has anyone experienced anything like this? Could there be an alignment issue with the way it was re-installed? The suggestions are to look for a lower transmission rear mount and install wedges at the axle. I found the 2 degree wedges at Summit and I'm wondering if I need 2 or 4 degrees. Do I need to pull the engine and trans to install a lowered rear mount? The other thing he noted was that the yoke is bottomed out on the rear of the transmission leaving me no play for the suspension. Potentially causing bearing wear. My first course of action will be to take the drive-shaft to the shop for evaluation and shortening. Thoughts on how much I should shorten it? The U-joints are an unknown. They flop around loosely when the drive shaft is out of the car. Not sure if they are supposed to be firm. There is no lateral slop in them. This is never-ending. All I want to do is drive my freakin' car.
