VERY OT - what I'm doing while on sick leave...
RickB
I've had both hands / wrists operated on for Carpal Tunnel over the holidays. I have one more week of sick leave before I return to work.
One of the things I've been doing actually for the past year is rebuilding my 8" Dobsonian telescope.
This is a Meade Starfinder I bought very cheaply on Craigslist several years ago. I was never very happy with the viewing from this thing so I thought I'd just rebuild it.
First I sent the primary mirror out to a place called NOVA Optical and got the thing tested then recoated with their highest reflective coating.
It's way better than new.
The viewing still sucked.
Next I thought about the focuser, the one that came with the scope was a rack & pinion job made almost entirely out of plastic. The rack had spots where it would stick so fine focusing was impossible.
I ordered a dual speed Crayford focuser, when I received it I had to show my kids as it was a perfect example of cheap crap versus quality materials and workmanship.
The old was also for 1.25" eyepieces and the new is for 2".
I also had to replace the finder scope, the cheap one it came with was useless.
I got a GSO 2 inch finder, which works great!
So I had to have a 2" eyepiece. I got a Baader Planetarium Hyperion 8mm - 24mm zoom. It's a really nice optic.
Still things didn't look good. Next I looked at my secondary mirror - yech. As with everything else on this scope the secondary was made of cheap junk.
It had black spidery crazing, and was not very reflective.
I got a new one, it's a small mirror so it was fairly inexpensive.
My hands felt good enough this week to work on that so I replaced the secondary mirror.
After alignment (Collimation) we had a nice clear night so I tried it out. I found that I could see the Orion Nebula but when I cranked up the lens it would fuzz way out.
This meant something was out of alignment.
After discussing the issue with another amateur astronomer who is into the hardware more than I am I got an idea.
I think I'm the only one who has tried this because I haven't read about doing it this way anywhere.
It is vital to have the primary, secondary and focusing tube all in alignment.
I put a center spot on my primary mirror, so I know that point is accurate.
What I don't know are many things, like:
1. Is the primary mirror mount "cell" centered in the tube?
It's a cheap POC so I have to assume the answer is no.
If it isn't then aligning everything else as if it were centered would cause problems.
2. Is the spider centered in the tube?
See the answer to #1 above.
Since it's actually most important to align these things relative to each other it's vital that the center of the spider be centered over the center of the primary mirror.
There is a hole in the center of the spider through which the secondary mount bolt is placed, a nut on the top holds it in place.
If a person were to slip a string through that hole and that string had a weighted pointer on the other end and it were long enough to reach almost to the primary mirror then a person could use a small level and make certain the tube was standing straight up (plumb) and then if the spider were centered that pointer inside would be pointing directly at the center spot on the primary mirror.
Yes, I'm talking about a plumb bob.
So I aligned it with a nice little home made plumb bob.
I found that the spider could not be centered properly as it came out of the factory so I had to use extra washers on two sides and none on two sides and then I could get it centered.
Then once everything was centered I collimated it and what do you know - it actually works.
It's way to hazy and cloudy to see much outside but I can focus on a fir tree about 1000 feet away and crank it up and see individual needles on the branches. Hopefully this will work well next time we have a clear night.
Nice! Star-gazing is fun.
We have a lot of light pollution here in Morris County, NJ so it's harder to see stuff in the heavens.
But sometimes we go out to our lake house (in a darker, more rural area of NJ) and star-gaze.
One of the neatest things is to sit on a row boat out there at around 2 AM in the middle of the lake and look for shooting stars. I've seen lots.
We have ~a new planetarium~ at work so sometimes I go in there and have my buddy run a show just for fun.
Oh yeah, that is fun.
I remember back when the comet hit Jupiter, that was fun to watch.
Last time I was at a planetarium was Griffith Observatory down in LA.
They had recently put in a new one and it was great.
I also got to see where they filmed Terminator, very fun for me as I am a fan.
Hey - I warned up front this would be off topic didn't I?
Last time that I was at Griffith park observatory I was in 3rd grade! It was great.
They also did parts of "The Rocketteer" there
BillM
When I was in school I developed a weather station for the astronomy professor. It used the weather, cloud coverage, etc to determine a rating for optimum astronomy viewing (he actually did photography).
It worked pretty well, just couldn't take turbulence into account (apparently it affects more than just your flight!).
If you are interested let me know and I would be happy to give you some of my research.
Neat... and to my way of thinking, there's nothing like a BIG reflector for deep space viewing. I'm partial to my ten inch Odyssey scope which is also a Dobsonian. Your eight inch sounds good.
Hey, wait a second, that was a LOT of typing in that post. Should you be doing that? :nonono:
Neat topic, thanks.
Rick,
WHY would you do both hands at the same time?
I had both wrists done - but my Wife pointed out-
how can you wipe,when you have to go?.....
- Doug
Well I had them done a few weeks apart, thus 6 weeks off work...
They were getting really bad, lots of numbness and pain.
Way better now, but don't think I wrote all that stuff in one sitting!!
Rick one thing we've got going for us in So Dak is very clean clear air. (We will unless they get the oil refinery built that is.) Been a great winter for star gazing with the sky just full of them! (Well, I guess they're always there just a little more visible)
Have'nt paid much attention to the night sky since I got married and stopped spending time parked on back roads with girls!!!
Kurt
I like showing things like nebulas and star clusters and galaxies to the kids, eventually they all have some astronomy in science class so it's good for that too.
I loved the sky in Wyoming, up around Sundance - WOW!!
