If he couldn't match it with the DuPont #'s then you may have to pick something off his paint chips that is "close" or find another supplier that can cross more numbers in his system.
True... maybe find out what paint system he uses, contact them and see if they can give you an equivalency? (Or have him get off his duff and do the same?)
im kinda confused too....
hes been in business as long
as i can remember, and comes
highly recommended...
the primer i picked up is Kirker brand,
...in business since 1893 or so...
should be good stuff....blood red
im almost ready for it :wink:
one quick tip.....
when bondoing..
keep the red glazing tube far away
from the red hardener tube...
glazing WILL NOT work as hardener!
doh! ............zimmmy
It may also be a matter of the duPont code not working in the type of paint you are wanting to spray. Check and see if he can cross it into another paint system (like base/clear)
I actually had the same problem - was PPC paint codes I was giving him and they wouldn't work with my guy's software - may be another quaint Canadianism.
