yesterday, I dropped off the Vauxhall HB SL axle to a fellow HB owner (it is too light for the GT). Before it went, I scavenged a couple of parts, including the slave cylinders. As I removed them, I noticed that one axle cylinder had a brake line in and a brake line out (not a bleeder) Upon inspection, I realized the brake line came from the Master, went to the one slave, then to the other, then to the bleeder. In other words, theoretically, you should only have to bleed one side on the back to have them all done.
I have never seen this arrangement before but it was curious. It seemed like a convenient way to ease bleeding but, potentially an unsafe situation as one damaged hose instantly empties both sides. (which is I know why they went to dual circuits)
Hi Guest!
