Gerard will do. Would rather buy "local" than go overseas. Still sorting out what I bought with Bugsy II. Needing to finish all of the welding as all of the panels were simply tack welded rather than finish welded didn't figure into my timeline. Alignment is really good and gaps are very, very small that will need to be finished but I had not counted on needing to do that. My MIG Skills will get a workout. Here is where a TIG would come in handy with being able to control much better rather than burning holes. Replacing beading on bonnet looks to be a major PITA. Bonnet straight other than RF Fender has a lot of bondo and some lumps on the curve on side of RF Headlight. Just need time to get in there with Dremel and cut out the beading, gloves, eye, and face protection definitely needed. Need to find some good metal prep stuff to treat the surface rust. Still calculating budgets and finding time to pull flywheel off and get out to you. I've spent the last week every night on Honey Do kitchen remodel and spring Cleanup outside Projects. At least another week before I can even find any time for Bugsy II.
A review of paperwork and receipts that came with Bugsy II shows that I appear to be the 3rd owner of a BE with < 24k miles on it. All of the accessories sitting in boxes are fairly clean, heater fan spins smoothly for example, stuff was kept dry and wiring harness, still supple and not all oily, greasy, hacked up. I haven't had time other than casual glances at stuff to put all of the restoration tasks in order. Bonnet will come first as it appears to be the toughest bodywork to fix. It will all be fixed in time. Hey thanks for the tip on seat kits.
