The Healey engine died at speed, twice. Although not offend. Once last summer and again just yesterday. Both times it turned out to be lack of fuel. i've been driving it alot, before, after and since with no troubles. I have two fuel pumps and they are controlled by two switches. These switches as Double Pole - Double Throw toggle switches. the reason I designed it this way is that I use the normally open contacts of each switch as an electrical interlock to keep the pumps from coming on at the same time. When one switch is on it opens the circuit to the other pump. that way each pump is intended as a back up, not as a volume enhancer. So anyway, this lack of fuel situation has at each time occurred just a few miles after a start up and comencing travel on the road. Each time it was about 2 miles after start up. Which I figure would be about the time it takes to drain the fuel bowls. I know that it is fuel starvation by a couple of charactoristics.
One is that the engine doesn't just die immediately, it just starts to slow down and then a fluttering gas pedal then it is dead. both times it happened that way. Usually when it is electrical, the engine would just quit , flat out stop dead , quickly. But this is a slow loss of speed and power over just a approx 30 seconds then no engine running.
So yesterday when it happened, I had just pulled out from a "Petro" station with a full tank of gasoline. I was motoring along a 2 lane road at constant speed of about 45 mph, just moments before i had slid it into 4th gear. I was about 2 miles away from the "Petro" station and all of a sudden, started loosing power. Tried to keep the revs up, pumped the gas, engine fluttered, then stopped. Luckily I coasted into a near driveway. Cranked engine, no start. Then I noticed the silence, no fuel pumps ticking. I flipped to 2nd pump, and still no ticking. Flipped toggle switches back and forth between pumps and still no ticking. Looked at voltage gauge, had good voltage and engine cranked normally. Thought, well I'd better check for spark. Let ignition switch on while going around to open bonnet and look over things, just popped straps on the distributor cap and ALL OF A SUDDEN i HEARD A FUEL PUMP TICKING. it was a good tick, constant for a period of time normally associated with the carb bowls filling up. Hmmm, weird now. Put the straps back down on the distributor cap, jumped into the driver's seat, hit the starter and it fired right up. Drove it home with no more trauma. So why did it run out of fuel at constant speed, with full tank of gas? Why did the pump just start pumping all of a sudden, even when I toggled between pumps just minutes before? I checked electrical connection, I had good voltage. And it only did this one other time a complete year earlier. Hmmmm? Any ideas? Thanks, Dave.
