Good moring everybody and Happy Saturday!
So I had my head done, Boiled, Magnafluxed, new seats, cut valves, ported, polished..... and all looks really good. I found a cam, a Crane 342-0010 and it also came with Larger valve springs. In fact they are double springs - Springs inside of springs. I took off one of the springs from my newly re-done head and the new spings I got with the Crane Cam do not fit. The smaller inner spring does not fit over the lower spring pan and for that matter neither does the valve spring cap. If I do not use the inner spring, then the outer spring is too loose/large. These springs were in a Piper package and obviously are not part of a Crane package I thought I was getting or might not be for the MGB head. I spoke to the guy who sold them to me and he is going to make good if I want him to.
I'm curious, are the stock springs fine for this cam? Are there other manufacturers that will make compatible springs. He asked that I send a stock spring cap and lower spring pan so he could find something that matches - Kent, piper etc.... I am not sure how important it is to have more or less spring pressure or I should not even bother and leave well enough alone. If there is no need for me to send him back the springs or try and have him match something for me, I won't.
Vince
Vince
Hi Guest!
