Thanks to everyone who mentioned the rope trick to get the head lifted off my TR250. It worked pretty slick once I stuffed enough rope in there. I was pretty amazed at how much rope it took and how easily it lifted the head.
Anyways, I'm picking the head up tomorrow from the machine shop after having the broken manifold stud removed and I want to clean everything before putting it back on the block. I know I got some paper material inside the intakes from the manifold gasket I scrapped off and I'm wondering who sells the best valve spring compressor for this application or if it really matters: will any spring compressor work? Or, would it be ok to pick out the larger pieces of material and let the smaller stuff get blown out without having to remove the valves?
