vping
I get in the am start it up until the temp gets to about 150º. After about 10 mins. of driving, my valves are making a racket but only mid range. At take off they are ok, then it's a bit noisy as I sped up a bit. During acceleration it sounds awsome up unitl I shift then it starts again.
This only happens when the engine is at normal temp.
I have the valves set at .015" hot but was thinking about changing to .013" hot.
Seeing it that is sounds fine when it is colder and not fully warm, but runs & pulls great, should I be looking at the valve clearance for a solution to the noise?
